To display the JMP Starter automatically when you open JMP on Windows, select File > Preferences > General, and then select JMP Starter from the Initial JMP Window list. On Macintosh, select this option on the JMP > Preferences > General page.
Figure 2.18 shows the JMP Starter window for Windows. The Macintosh JMP Starter window is identical.
Figure 2.18 The JMP Starter Window (Windows)
