From the JMP Starter window, you can launch a specific analysis (Bivariate, Oneway, Logistic, or Contingency). If you select this option, specify the correct modeling types (Y and X variables) for the analysis. See Table 4.1.
To launch a specific analysis from the JMP Starter Window, click the Basic category, and select a specific analysis.
