When you launch the Control Chart platform by selecting Analyze > Quality And Process > Control Chart, you will see a Control Chart Launch window similar to Figure 4.3. The exact controls vary depending on which type of chart you select. Initially, the window shows the following types of information:
Figure 4.3 XBar Control Chart Launch Window
Help created on 3/19/2020
