Launch the MaxDiff platform by selecting Analyze > Consumer Research > MaxDiff.
For the One Table, Stacked format, the data are in a single data table. There is a row for every profile presented to a subject within a choice set and an indicator for the best and worst profiles in that choice set. The Potato Chip Combined.jmp sample data table contains the results of a MaxDiff experiment in a single table format. See One Table Format.
For more information about the launch window for this format, see Launch Window for One Table, Stacked.
The Potato Chip Profiles.jmp, Potato Chip Responses.jmp, and Potato Chip Subjects.jmp sample data tables contain the results of a MaxDiff experiment using three tables. See Multiple Table Format.
