Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Summarize Data
Summarize Columns
• Launch Window Roles
JMP.com/help
Launch Window Roles
Statistics
Defines the summary statistics (such as mean, standard deviation, and median) for a numeric column in the source table. See
Add Summary Statistics
for details.
Group
Summarizes the statistics by group. See
Use One or More Grouping Columns
for details.
Subgroup
Summarizes the statistics by subgroup. See
Create a Two-Way Table of Summary Statistics by Adding a Subgroup Variable
for details.
Freq
Identifies a column whose values assign a frequency to each row.
Weight
Identifies a column whose values assign a weight to each row.
Help created on 3/19/2020
