When using constraints, unfeasible regions are shaded in the profiler. Figure 6.7 shows an example of a mixture profiler with shaded regions due to four constraints. The unshaded portion is the resulting feasible region. The constraints are below:
p1 + 2*p2  0.95
Figure 6.7 Shaded Regions Due to Linear Constraints
Help created on 3/19/2020
