A lock icon
appears next to the data table name. To unlock the file, select Lock Data Table again.
If you make a data table read-only outside of JMP (for example, by changing its properties on Windows), the data table contains a note informing you that it is locked. See Figure 4.48. This type of lock allows users to edit the data table, but not save the changes.
