Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Modeling Utilities
• Make Validation Column Utility
JMP.com/help
Validation is the process of using part of a data set to estimate model parameters and using another part to assess the predictive ability of a model. With complex data, this can reduce the risk of model overfitting.
A validation column partitions the data into two or three parts.
The training set is used to estimate the model parameters.
The validation set is used to help choose a model with good predictive ability.
The testing set checks the model’s predictive ability after a model has been chosen.
A validation column can be used as a validation method in the Fit Model platform.
Help created on 3/19/2020
