Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
MaxDiff Design
• MaxDiff Design Launch Window
JMP.com/help
To use the MaxDiff Design platform, you need a starting data table. Your starting data table must contain a column of character data that lists the items to be presented to respondents for rating.
With your starting data table active in JMP, select
DOE > Consumer Studies > MaxDiff Design
. If you have no active data tables, you are prompted to navigate to your starting data table.
Figure 19.6
MaxDiff Launch Window using Candies.jmp
X, Factor
The character column that contains the items that respondents will rate.
Help created on 3/19/2020
