Similarly, the R|C denotes that the column variable Y is regarded as an independent variable and the row variable X is dependent.
Notes:
For computational details about the measures of association statistics, see the FREQ Procedure chapter in the SAS/STAT 14.3 User’s Guide (2017). The following references also contain additional information:
Help created on 3/19/2020
