Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Mixture Designs
• Mixture Design Window
JMP.com/help
The mixture design window updates as you work through the design steps. For more information, see
The DOE Workflow: Describe, Specify, Design
. The workflow and outlines vary depending on design type.
Figure 13.2
Mixture Design Workflow
Help created on 3/19/2020
