Shows the T2 chart. Hotelling’s T2 chart is a multivariate extension of the XBar chart that takes correlation into account.
Constructs multivariate control charts based on the principal components of Y. Specify the number of major principal components for T2. See T Square Partitioned.
Creates a new column in the data table. Stores a formula in the column that calculates the T2 values.
(Not available for sub-grouped data) Shows a Change Point Detection plot of test statistics by row number and indicates the row number where the change point appears. See Change Point Detection.
