Naive Bayes Platform Options
Saves a column called Naive Predicted Formula <Y, Response> to the data table. This column contains the prediction formula for the classifications.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 3/19/2020
