Tip: For a one-sided test, use α = α *2. For a one sided test with α = 0.05, use the two-sided calculator with α = 0.10. The resulting values are those needed for a one-sided test with α = 0.05.
The number of parameters other than μ in the hypothesis test. This option can be used for multi-factor designs. Leave the default zero in this field for simple cases.
Help created on 3/19/2020
