Shows or hides an Odds Ratios report that contains Unit Odds Ratios and Range Odds Ratios, as shown in Figure 11.6.
Figure 11.6 Odds Ratios
(Available only for two-level nominal responses.) Finds the x value that results in a specified probability. See the appendix Statistical Details for more information about inverse prediction.
For a nominal response model with r levels, JMP creates the following columns:
columns called Lin[j] that contain a linear combination of the regressors for response levels j = 1, 2, ... r - 1
a column called Prob[r], with a formula for the fit to the last level, r
columns called Prob[j] for j < r with a formula for the fit to level j
a column called Most Likely response name that selects the most likely level of each row based on the computed probabilities.
Publish Probability Formulas
Help created on 3/19/2020
