Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Graph Builder
Right-Click Menus
• Options for the Dividing Line between Multiple Graphs
JMP.com/help
This menu appears only if you have two or more graphs in the graph area. Right-click on the line that separates graphs. Options appear that change the formatting of the line, such as color, transparency, spacing, and borders.
Tip:
If the line between the graphs is too thin, you can resize it. Click the Graph Builder red triangle, select
Graph Spacing
, and enter a larger value.
Help created on 3/19/2020
