This section gives the density functions f for the distributions used in the Process Capability platform. It also gives expected values and variances for all but the Johnson distributions.
E(X) = μ
Var(X) = σ2
E(X) =
Var(X) =
E(X) = σ
Var(X) = σ2
E(X) = ασ
Var(X) = ασ2
E(X) =
Var(X) =
E(X) =
Var(X) =
where μi, σi, and πi are the respective mean, standard deviation, and proportion for the ith group, and is the standard normal probability density function. For the Mixture of 2 Normals, k is equal to 2. For the Mixture of 3 Normals distribution, k is equal to 3. A separate mean, standard deviation, and proportion of the whole is estimated for each group in the mixture.
E(X) =
Var(X) =
Help created on 3/19/2020
