Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Formula Functions Reference
• Parametric Model Functions
JMP.com/help
This category is a short cut to create three parametric models that are linear functions of set of window-selected columns.
Linear Model, Interactions Model, Full Quadratic Model
Selecting each of these opens a column selection box that lets you select one or more columns to be included in the model. The function then creates and populates the chosen model.
Help created on 3/19/2020
