Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
• Personalize JMP
JMP.com/help
Personalize JMP
Customize Menus and Toolbars
This chapter describes how to customize JMP menus and toolbars to show only the commands that you need. For example, you might remove the SAS option in the File menu if you do not use SAS. Or you might assign a shortcut key to the Run Script command.
Customizing JMP also lets you set up JMP for groups with special interests. If one group does not design experiments, you could remove DOE from the JMP menu.
Contents
Personalize Toolbars and Menus on Windows
Change Customization Sets
Create Toolbars
Create Main Menus
Create Menu Items and Toolbar Buttons
Rearrange Toolbars
Copy and Paste Menus, Menu Items, Toolbars, and Buttons
Rearrange Custom Menus, Menu Items, and Buttons
Delete Custom Items
Show and Hide Items
Import Customizations
Remove Customizations
Personalize Toolbars on Macintosh
Personalize Menu Items on Macintosh
Customize Menus and Toolbars for an Add-In
Help created on 3/19/2020
