Raw effect size. For details about effect size computations, see Effect Size in the Fitting Linear Models book. The first position is initially set to the square root of the sums of squares for the hypothesis divided by n; that is, .
Solves for the value of the parameter or linear test that produces a p-value of α. This is a function of α, σ, n, and the standard error of the estimate. This feature is available only when the X factor has two levels and is usually used for individual parameters.
Adjusted power and confidence limits are computed only for the original Delta, because that is where the random variation is.
Help created on 3/19/2020
