Enables you to save the Profiler (with reduced functionality) as an Adobe Flash file, which can be imported into presentation and web applications. An HTML page can be saved for viewing the Profiler in a browser. The Save for Adobe Flash platform (SWF) command is not available for categorical responses. For more information about this option, go to https://www.jmp.com/support/swfhelp/.
Creates code for the OPTMODEL SAS procedure. Hold down Ctrl and Shift and then select Formulas for OPTMODEL from the red triangle menu.
The following options are available in many platforms. See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information.
