the Select Columns box
(Available only for Shewhart Variables charts that have a column with a Spec Limits column property.) Shows or hides the Process Capability Analysis report. For more information about the Process Capability Analysis report, see The Process Capability Report.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
