Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Graph Builder
• Red Triangle Options
JMP.com/help
The red triangle menu for Graph Builder contains these options:
Show Control Panel
Shows or hides the platform buttons, the Select Columns box, and the drop zone borders.
Show Legend
Shows or hides the legend.
Legend Position
Sets the position of the legend. The legend appears on the right by default. Putting the legend at the bottom places it in the center below the graph. The legend items then appear horizontally instead of vertically. Or, you can put the legend inside the graph, on the left or right.
Legend Settings
Opens a window where you can modify legend settings, such as the title, font, and title position.
Continuous Color Theme
Selects the color theme for continuous variables.
Categorical Color Theme
Selects the color theme for categorical variables.
Note:
For more information about color themes, see
Create Color Themes
in the
Using JMP
book.
Show Title
Shows or hides the graph title. Right-click to change the alignment or the span of the title.
Show Subtitle
Shows or hides the graph subtitle. Right-click to change the alignment or the span of the subtitle.
Show Footer
Shows or hides the footer, which contains informative messages such as missing map shapes, error bar notes, frequency notes, and WHERE clauses.
Lock Scales
Prevents axis scales and gradient legend scales from automatically adjusting in response to data or filtering changes.
Link Page Axes
Links or unlinks graph axis scales across levels of the By group variable in the Page zone.
Fit to Window
Determines whether the graph is resized as you resize the JMP window. The default setting is Auto, which is usually set to On except when the window is shared with other content or if there is a Page variable. To always fit the graph inside the window, keep the setting at On. You can also maintain the aspect ratio. To prevent the graph from resizing, change the setting to Off.
Sampling
Uses a random sample of the data to speed up graph drawing. If the sample size is zero, or greater than or equal to the number of rows in the data table, then sampling is turned off.
Graph Spacing
Sets the amount of space between graph panels.
Include Missing Categories
Enables a graph to collect and display missing values for categorical variables.
Set Alpha Level
Enables you to set the Alpha level for graphs and statistics that use an alpha value for confidence intervals.
Launch Analysis
Launches the Fit Model platform with the variables on the graph placed into roles. It launches the Distribution platform when only one variable is placed.
Make into Data Table
Creates a new data table that contains the results from the graph.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Help created on 3/19/2020
