Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Logistic Regression Models
Statistical Details for the Nominal and Ordinal Logistic Personalities
• Relationship of Statistical Tests
JMP.com/help
All of the statistical tests in the Logistic Regression reports compare the fit of the specified model with subset or superset models, as illustrated in
Figure 11.14
. If a test shows significance, then the higher order model is justified.
Whole model tests: if the specified model is significantly better than a reduced model without any effects except the intercepts.
Lack of Fit tests: if a saturated model is significantly better than the specified model.
Effect tests: if the specified model is significantly better than a model without a given effect.
Figure 11.14
Help created on 3/19/2020
