Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Enter and Edit Data
Enter Data
• Replace Missing Values with Previous Values
JMP.com/help
When a column contains missing values, you can replace those values with the value in the preceding cell. For example, if “4, .,., ., ., 6, ., ., 7, .” is selected, the values are changed to “4, 4, 4, 4, 4, 6, 6, 6, 7, 7”.
Select the cells that contain the missing and replacement values.
The first cell that you select must immediately precede a missing value. After that, you can select non-adjacent cells.
Figure 4.5
Missing Values
Right-click and select
Fill > Replace Missing with Previous Value
Figure 4.6
Replaced Values
Help created on 3/19/2020
