Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Consumer Research
Categorical Response Analysis
Categorical Platform Options
• Report Options
JMP.com/help
Report Options
Frequencies
Shows or hides the frequency in the Crosstab table. The frequency is the count of the responses in each category.
Share of Responses (Share)
Shows or hides the share of responses in the Crosstab table. The share of responses is the percent of responses in each category.
Rate Per Case (Rate)
(Available only for multiple responses.) Shows or hides rate per case in the Crosstab table. The rate per cases is the percent of responses in each category based on the total number of cases (regardless of if they were a respondent).
Rate per Case Responding
(Available only for multiple responses.) Shows or hides rate per case responding in the Crosstab table. The rate per case responding s is the percent of responses in each category based on the cases that responded.
Share Chart
Shows or hides a divided bar chart. The bar length is proportional to the percentage of responses for each type. The column on the right shows the number of responses in each grouping category. If no grouping category is used, the column on the right shows the total number of responses.
Tip:
You can change the colors in the share chart using the Value Colors column property. See
Value Colors
in
Using JMP
Frequency Chart
Shows or hides a Frequency Chart. The bars reflect the frequency of responses within each group. The scale is consistent across the chart. The gray bars at the far right are the total number of responses in each grouping category.
Tip:
You can change the colors in the frequency chart using the Value Colors column property. See
Value Colors
in
Using JMP
Transposed Freq Chart
Shows or hides a transposed Frequency Chart. The bars reflect the frequency of responses within each group. The responses are the rows and the grouping levels are the columns in chart. The totals for each grouping level are represented by gray bars in the bottom row of the chart.
Crosstab
Shows or hides the Crosstab table. The Crosstab table displays the response categories as column headings, and displays the grouping levels (when used) as row labels. The upper left cell of the table shows the labels for the items in each cell of the table (Freq, Share, and Rate). If the report contains a transposed Crosstab table, this option removes the transposed Crosstab table from the report.
Crosstab Transposed
Shows or hides a transpose of the Crosstab table. The transposed Crosstab table displays the response categories as row labels, and displays the grouping levels (when used) as column headings. The upper left cell of the table shows the labels for the items in each cell of the table (Freq, Share, and Rate). If the report contains a Crosstab table, this option removes the Crosstab table from the report.
Help created on 3/19/2020
