Provides profilers, interaction, and cube plots to examine how the response is related to the model terms. Also provides a plot and report for fitting a Box-Cox transformation. See Factor Profiling.
Provides plots and reports for examining residuals. Also reports the PRESS statistic and provides a Durbin-Watson test. See Row Diagnostics.
Saves model results as columns in the data table, except for Save Coding Table, which saves results in a separate data table. See Save Columns.
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See Effect Summary Report.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
