The Simple tab contains an option for the analysis of results that are contained in a single column.
Summarizes data from multiple columns where each column contains responses made at different time points. When an individual responds at multiple time points, the samples are called overlapping. When there are overlapping samples, the Kish correction is used. See Kish (1965, sec. 12.4).
Summarizes text data. The Free Text option launches a Text Explorer report inside the Categorical report window. See Text Explorer in the Basic Analysis book.
