Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Response Surface Designs
• Response Surface Design Window
JMP.com/help
The Response Surface Design window walks you through the steps to construct a design for modeling a quadratic surface. You can select a central composite design, a Box-Behnken design, or a blocked version of one of these design types. If you select a central composite design, you can adjust the axial points.
The Response Surface Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in
Figure 11.12
Figure 11.12
Response Surface Design Flow
Help created on 3/19/2020
