Run charts display a column of data as a connected series of points. The following example is a Run chart for the Weight variable from Coating.jmp in the Quality Control sample data folder (taken from the ASTM Manual on Presentation of Data and Control Chart Analysis).
Select Analyze > Quality and Process > Control Chart > Run Chart.
Click OK.
Figure 4.16 Run Chart
