Select File > Database > Save Table.
Figure 10.1 The Database Save Table Window
In the Connections box, highlight the name of the database to which you want to save the file (shown in Figure 10.1). The Connections box contains a list of databases to which your system is connected.
From the JMP data table to be saved menu, select the open JMP data table that you want to save to the database.
In the Save to database table box, enter the name that you want the table to have when you save it in the database.
6.
Click Save Table.
Click Connect.
Select the data source that you want and click OK. Or, to create a new source, click the New button (Windows) or Add button (Macintosh).
