Figure .13 Example of a Scatterplot Matrix
This example uses the Solubility.jmp data table, which contains data for solubility measurements for 72 different solutes.
Figure .14 Scatterplot Matrix Window
Click OK.
Figure .15 Scatterplot Matrix
The data points in the scatterplot for Benzene and Chloroform are the most tightly clustered along an imaginary line.
For example, if you select a point in the Benzene versus Chloroform scatterplot, the same point is selected in the other five plots.
Figure .16 Selected Points
