The Screening Design window updates as you work through the design steps. For more information, see The DOE Workflow: Describe, Specify, Design. The outlines that appear are separated by buttons that update the window. These follow the flow in the figures below.
Figure 9.11 Screening Design Flow when a Standard Design Exists
Figure 9.12 Screening Design Flow when No Standard Design Exists
Help created on 3/19/2020
