Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Multiple Correspondence Analysis
Multiple Correspondence Analysis Platform Options
• Show Coordinates
JMP.com/help
Show Coordinates
Shows the Column Coordinates table or the Row and Column Coordinates tables.
X
Lists the columns specified as X, Factor variables.
Y
Lists the columns specified as Y, Response variables.
Z
Lists the columns specified as Z, Supplementary Variables.
Category
Lists the levels of the X, Y, or Z variables.
Dimension 1, Dimension 2, Dimension 3
For each level or each response, lists its coordinate along the indicated principal axis. By default, the tables show coordinates for up to the first three dimensions. Coordinate columns for additional dimensions are hidden. To show these optional columns, right-click in a table and select the dimension columns from the
Columns
submenu.
Note:
If there are columns specified as X, Factor variables, the Coordinates report displays tables of both X and Y with the same report headings. If a Z, Supplementary Variable is specified, the coordinates are listed below the X and Y coordinates as applicable.
Help created on 3/19/2020
