A simplex centroid design of degree k with n factors consists of mixtures with the following characteristics:
Select DOE > Classical > Mixture Design.
Click Continue.
Click Simplex Centroid to generate the design
Note: The default setting of k = 2 was used. There is a text box that enables you to adjust the value of k.
Click Make Table.
6.
From design table, select Graph>Ternary Plot.
7.
Figure 13.9 Ternary Plot for Simplex Centroid Design
