If columns contain value labels, sorting is based on the actual data values, not the value labels. (See Value Labels in The Column Info Window.) However, the value labels are displayed in the sorted data table.
Select Tables > Sort.
Figure 6.5 The Sort Window
Click By to add the columns to the sort list.
Customize your sort further using the additional options. For this example, highlight yield and click the descending button.
6.
Enter a name for the new sorted table in the box beside Output table name. For this example, enter sorted popcorn.
Figure 6.6 Completed Sort Window
7.
Click OK.
Figure 6.7 Sorted in Ascending and Descending Order
