Select a life distribution (Weibull or LogNormal) for each acceleration factor. For more information, see Statistical Details for the ALT Design Platform.
(Available only for Monitoring at Intervals.) Specify the times at which inspections are conducted. When you make the design table, these times are used to construct Start Time and End Time columns. The number of units failing in each interval is recorded.
