Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Destructive Degradation
Launch the Destructive Degradation Platform
• Specify Two Y Columns
JMP.com/help
You can specify two Y columns when some of the degradation measurements are interval censored or left censored. For a given row, values in the two Y columns are handled as follows:
If the two Y values are equal and neither is missing, then the common measurement is treated as exact.
If the two Y values are not equal and neither is missing, then the measurement is interval censored and assumed to be between the two values.
If only the first value is missing, then the measurement is left censored and assumed to be smaller than the second value.
If only the second value is missing, then the measurement is right censored and assumed to be larger than the first value.
Note:
The only way to fit left-censored measurements in the Destructive Degradation platform is through the use of two Y columns.
Help created on 3/19/2020
