The Main Effect Estimates report lists main effects that are identified as active. Main effects with p-values less than the threshold p-value are considered active.
Main effects identified as active. These effects have p-values less than the threshold when tested as described in Stage 1 Methodology.
The p-value computed using the t Ratio and the degrees of freedom for error (DF).
