The Test Statistic is distributed as a Chi-square variable with n - 1 degrees of freedom when the population is normal.
The Min PValue is the p-value of the two-tailed test, and is calculated as follows:
where p1 is the lower one-tail p-value and p2 is the upper one-tail p-value.
Help created on 3/19/2020
