Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
The Column Info Window
Standardize Attributes and Properties Across Columns
• Standardize Attributes
JMP.com/help
By default, the items within the Standardize Attributes panel are dimmed. To access an item, click the
Attributes
button and select the items to be duplicated across columns.
Note:
The Input Format item is applicable only for the Date, Time, and Duration formats.
To change the values of any of the attributes, use the menus in the Standardize Attributes panel.
Help created on 3/19/2020
