Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Multidimensional Scaling
• Statistical Details for the Multidimensional Scaling Platform
JMP.com/help
JMP uses a quasi Newton optimization method to minimize the Stress function to determine the MDS coordinates. This minimization leads to a set of coordinates in a predetermined number of dimensions that minimize the derived proximity measures for each pairwise set of the dimensions. When the data is ordinal, monotonic regression is used. Otherwise, standard least squares regression is used.
Stress
Transformations
Attributes List Format
Help created on 3/19/2020
