Select Analyze > Distribution to open the Distribution launch window.
Click OK.
Figure .6 Distribution Report Window on Windows
On Windows, click the data table button in the lower right corner to view the data table that was used to create this report. On Macintosh, click the Show Data Table button in the upper right corner of the report window.
On Windows, click the JMP Home Window button in the lower right corner to view the Home Window. On Macintosh, select Window > JMP Home.
