Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Taguchi Designs
• Taguchi Design Window
JMP.com/help
The Taguchi Design window updates as you work through the design steps. For more information, see
The DOE Workflow: Describe, Specify, Design
. The outlines, separated by buttons that update the outlines, follow the flow in
Figure 14.8
Figure 14.8
Taguchi Design Flow
Help created on 3/19/2020
