Follow the instructions in Example of the Distribution Platform to produce the report shown in Figure 3.5.
Note: If you apply only the Hidden row state to rows in the data table, the corresponding points do not appear in plots that show points. However, histograms are constructed using the hidden rows. If you want to exclude rows from the construction of the histograms and from analysis results, apply the Exclude row state. Then select Redo > Redo Analysis from the red triangle menu next to Distributions.
The red triangle menu next to each variable contains options that affect only that variable. See Options for Categorical Variables or Options for Continuous Variables. If you hold down the Control key and select a variable option, the option applies to all of the variables in the report that have the same modeling type.
