The Scripting Index on the Help menu provides a brief description and the syntax for JSL functions, objects, and display boxes. Each entry includes an example that you can run and modify to test your own code. And an embedded log window lets you see messages as examples are run.
Click the Clear button to clear the search text box to begin a new search.
Help created on 3/19/2020
