Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Stepwise Regression Models
• The Stepwise Report
JMP.com/help
The Stepwise Report
The Stepwise report window contains the following elements:
Platform options
The red triangle menu next to Stepwise Fit contains options that affect all of the variables. See
Stepwise Platform Options
Stepwise Regression Control
Controls that limit regressor effect probabilities, determine the method of selecting effects, start or stop the selection process, and create a model. See
Stepwise Regression Control Panel
Current Estimates
A report that enables you to add, remove, and lock in model effects. See
Current Estimates Report
Step History
A report that records the effect of adding a term to the model. See
Step History Report
Help created on 3/19/2020
