ALPHA_TEST
AUTO_NORMAL
BLEND
CLIP_PLANE0
CLIP_PLANE1
CLIP_PLANE2
CLIP_PLANE3
CLIP_PLANE4
CLIP_PLANE5
COLOR_LOGIC_OP
COLOR_MATERIAL
CULL_FACE
DEPTH_TEST
DITHER
FOG
LIGHT0
LIGHT1
LIGHT2
LIGHT3
LIGHT4
LIGHT5
LIGHT6
LIGHT7
LIGHTING
LINE_SMOOTH
LINE_STIPPLE
MAP1_COLOR_4
MAP1_INDEX
MAP1_NORMAL
MAP1_TEXTURE_COORD_1
MAP1_TEXTURE_COORD_2
MAP1_TEXTURE_COORD_3
MAP1_TEXTURE_COORD_4
MAP1_VERTEX_3
MAP1_VERTEX_4
MAP2_COLOR_4
MAP2_INDEX
MAP2_NORMAL
MAP2_TEXTURE_COORD_1
MAP2_TEXTURE_COORD_2
MAP2_TEXTURE_COORD_3
MAP2_TEXTURE_COORD_4
MAP2_VERTEX_3
MAP2_VERTEX_4
NORMALIZE
POINT_SMOOTH
POLYGON_OFFSET_FILL
POLYGON_OFFSET_LINE
POLYGON_OFFSET_POINT
POLYGON_SMOOTH
POLYGON_STIPPLE
SCISSOR_TEST
STENCIL_TEST
