s is the standard deviation
t is the quantile from the non-central t-distribution
where s is the standard deviation and is a constant.
To determine g, consider the fraction of the population captured by the tolerance interval. Tamhane and Dunlop (2000) give this fraction as follows:
where Φ denotes the standard normal cdf (cumulative distribution function).
Therefore, g solves the following equation:
where 1 - γ is the fraction of all future observations contained in the tolerance interval.
The lower 100(1 - α)% one-sided tolerance limit to contain at least a proportion β of the sampled distribution from a sample of size n is the order statistic x(l). The index l is computed as follows:
where Φ-1bin(1-αnβ) is the (1 - α)th quantile of the binomial distribution with n trials and probability of success β.
The actual confidence level is computed as Φbin(n-lnβ), where Φbin(xnβ) is the probability of a binomially distributed random variable with n trials and probability of success β being less than or equal to x.
The upper 100(1 - α)% one-sided tolerance limit to contain at least a proportion β of the sampled distribution from a sample of size n is the order statistic x(u). The index u is computed as follows:
The actual confidence level is computed as Φbin(u-1, nβ), where Φbin(xnβ) is the probability of a binomially distributed random variable with n trials and probability of success β being less than or equal to x.
The 100(1 - α)% two-sided tolerance interval to contain at least a proportion β of the sampled distribution from a sample of size n is computed as follows:
where x(i) is the ith order statistic and l and u are computed as follows:
Let ν = n - Φ-1bin(1-αnβ), where Φ-1bin(1-αnβ) is the (1 - α)th quantile of the binomial distribution with n trials and probability of success β. If ν is less than 2, a two-sided distribution-free tolerance interval cannot be computed. If ν is greater than or equal to 2, l = floor(ν/2) and u = floor(n + 1 - ν/2).
The actual confidence level is computed as Φbin(u-l-1, nβ), where Φbin(xnβ) is the probability of a binomially distributed random variable with n trials and probability of success β being less than or equal to x.
Help created on 3/19/2020
