(Available only in the Transfer Function Analysis red triangle menu.) Shows the Transfer Function Model Specification window. Building a transfer function model is similar to building an ARIMA model; it is an iterative process of exploring, fitting, and comparing models. Before building a model and during the data exploration process, it is sometimes useful to prewhiten the data. See Prewhitening. For more information about transfer functions, see Statistical Details for Transfer Functions.
Note: Currently, the transfer function model platform has limited capability of supporting missing values.
Once you specify the models and click Estimate, a Model Report for each specified model is added to the report window. See Reports.
Creates a new data table containing the spectral density and periodogram where the (i+1)th row corresponds to the frequency fi = i / N (that is, the ith harmonic of 1 / N). The new data table has the following columns:
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
